Recently every time I played Crysis 3 I will encounter system shut down and reboot, and the message "power surge detected' pop out. This happens after switching from AMD FX8350+Asus Crosshair V Formular to Intel i7 3770k+Asus Sabertooth z77, other components are from my previous rig. My psu is Corsair HX850W, and I have used it for more than 1 year. I heard it maybe the psu issue, though it works totally fine on previous rig. I don't have another psu to test out, so I am not sure if this is the psu issue. The system is never been overclocked.
So whats your opinion? Any advice will be appreciated.
What I have done include:
I also try to flash the bios to previous one, no help.
Try to clean the psu, there are not too mush dust there.
I try to disable the power suge detected in bios, but it is not working, still power surge detected.
I have monitor the voltage while playing other game like Far Cry 3, the results are in normal range ( +12v/12.096, +5V/5.000V, +3.3/3.328V)
Test prime95 stress test about 3 hours, nothing happens.
Test with Intel burn test, and system pass the test, the constant results show the cpu is stable
My pc spec are:
i7-3770k
Asus Sabertooth z77
Corsair Dominator GT 4GBx4
EVGA GTX 690
OCZ Vertex 4 128GB (OS)
1 usb hub which has its own power supply
My pc spec are:
i7-3770k
Asus Sabertooth z77
EVGA GTX 690
