Asus Power Supply Surge Detected
mowgli.gregory1
21
I just put a second hard drive in my computer, then a couple minutes after playing any blizzard game, my computer would crash and say
"Power Supply Surges detected during the previous power on.
ASUS Anti-Surge was triggered to protect system from unstable power supply unit! "
I then took the second hard drive out and this is still happening. My current psu is only 300W. Is my psu the problem?
Anti-surge message usually mean that the motherboard detected out-of-spec voltages coming from the PSU. Yes, that would usually mean there is a problem with the PSU.
If you have a computer case which can take standard ATX-size PSUs, get a good quality replacement PSU such as Seasonic's 520-620W S12-II which can often be found for as little as $40.
I thought I had a 300w psu but i checked and it turns out I have a 550 W psu
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151119&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Power+Supplies-_-N82E16817151119&gclid=EAIaIQobChMI5qqW5--g1gIVAzFpCh1ifgNREAYYASABEgIWLPD_BwE&gclsrc=aw.ds
Latest posts
