Question ASUS POWER SURGE
diogoricar2010
19
So, everytime I play CS or rocket league my PC just restarts and I get the error that a power surge was detected, I've been trying to fix this problem for months now to the point I just gave up on trying, I don't know whether it is a faulty PSU or something else, so I thought I'd ask if any of you know any possible solutions
SPECS:
I7 7700k
Rx 5700xt
NX 750W
ASUS H170 Pro Gaming
DSzymborski
Glorious
Not doubting you obviously, but would you say it's safe to spend money on a new PSU? Thats my biggest fear, to just throw money down the drain
It's not money down the drain; you ought to replace the PSU whether or not it is what's causing your problem. Your biggest worry should be investing in an i7 and a 5700xt while not providing it safe, clean power proportional with your investment. Nox and Tacens sell a lot of sorta-junk, especially in Spain.
diogoricar2010
19
Portuguese here, but the PC market is pretty much the same to be honest, what PSU would you recommend me for the build?
diogoricar2010
19
Generally speaking, Corsair TX/RM/RMx, SeaSonic Focus/Prime, EVGA G2/G3/B2/T2/P2, Antec HCG. A Super Flower Leadex if you have them there (they pop up in some European countries, not sure about Portugal).
Is the 80+ gold enough? Or is platinum where it should be at? Edit: is this one good for the specs I have? https://www.globaldata.pt/fonte-seasonic-core-gc-650w-80-gold-core-gc-650?gclid=CjwKCAiAi4fwBRBxEiwAEO8_HlYYkBKnoKpUamdloi7qllCyLEo0YVg-sI3E9vVXif97fxgiM3Kn0xoCLtwQAvD_BwE
DSzymborski
Glorious
You don't need Platinum, the Gold one is already an excellent PSU. This will keep your valuable parts safe for a decade or longer. Hopefully, it will also resolve the problem, but if it doesn't, we've got a questionable PSU out of the equation.
Dark Lord of Tech
темный лорд технологий
127,308
1,385
154,890
25,080
Here's 4 to look at:
https://www.globaldata.pt/componentes/fontes/fonte-bitfenix-formula-650w-80-gold-bp-fm650ulag-9r
https://www.globaldata.pt/componentes/fontes/fonte-modular-seasonic-focus-gx-650w-80-gold-focus-gx-650
diogoricar2010
19
If it doesn't what would be your next suggestion? Maybe faulty mobo?
DSzymborski
Glorious
Possibly. The next thing I'd do in that case is to try removing the GPU and run everything on the integrated GPU for testing. The more things you can eliminate, the fewer things it can be. Think of a troubleshooting challenge like a list of components and crossing out the things verified to work with a red marker.
diogoricar2010
19
Thanks for the suggestions
diogoricar2010
19
Right, I actually just switched the gpu 3 months ago, and I had the issue before as well, so I believe I can cross that, same with CPU
Reactions: Dark Lord of Tech
