Running Prime H510M-E with i-5 10400:
When I change the fan setting in armory to one of the four icons, for instance "standard" setting, the fan rpms ramp up during high temps, but rpm's DON'T go back down after the cpu is cool at idle. It seems to not work according to other peoples experiences as well. If I run Armory and don't touch the fan settings, it follows the fan curve set in the bios, which is fine. I don't see anywhere in Armory, at least my version, to set a fan curve. Thoughts?
Is there a simple freeapp to replace this functionality? I really just want to see cpu load, temps, rpm's, and maybe be able to adjust fan curves without having to reset into my bios.
