Asus' Project Avalon: A Functional Modular Motherboard And Chassis
jlr01
40
Hope they could make both budget and server grade modular motherboards, that would just make troubleshooting a lot easier.
bit_user
Ambassador
Hot-swap disks & power supplies are nothing new. It's standard in servers, and not uncommon in PC-based workstations. It just adds a lot of cost for a little convenience and wow-factor.
Do we know whether the case will work with standard ATX power supplies via some kind of adapter, or would this case limit you to PSUs designed specifically for it?
Not that I'd buy one, either way. Just curious how much compatibility people would be sacrificing for the premium price they'd surely have to pay.
Phuntasm
31
Absolutely nonsensical idea. I have no idea what the target market is.
It's incredibly ugly to boot. They are going for some kind of home theater look with 80s styling, but the whole thing just looks awkward and bulky.
Beholder88
38
I would buy something like this as an HTPC. The possibilities for this and the tech created to support it could bleed into other areas. If all I wanted was an HTPC or a customer NAS box, I could tailor the modules I need for just those uses.
arneberg
I have waited for this like 20 years but want more flexibility like x99 or upcoming Skylake-e and more flexibility with how many graphic cards you can put in and memory put in a sas also and lots of U.2 and i would be grateful flexibility is the key otherwise it´s only a special.
f-14
Its like travelling back in time to when you had to buy sound cards and IO cards separately.
you must be a millennial, go back further to daughter boards and ram extension slots
https://ancientelectronics.files.wordpress.com/2012/11/wang5.jpg
https://tonystecnophilia.files.wordpress.com/2015/08/wpid-dell-precision-workstation-690-pc-ram-memory-riser-card-set-m9008-j9272-jf807_2616660613301.jpg
https://xdevs.com/oc/pure/pcim6.jpg
http://yesterbits.com/wp-content/uploads/2012/06/terraiiplus-microsoft-ram.jpg?imgmax=800
http://www.nekochan.net/photos/PICT1344.JPG
http://cdn.overclock.net/a/a6/a642264a_RSC-R2UG-A2E16-A.jpeg
Well, right now the actual chipset and CPU support for this board isn't important, because if the project is successful and leads to actual products on the market, we will see multiple motherboards and chipsets. Put simply, Asus isn't going through all of this trouble for a single platform.
