What have I done wrong? At first I obviously applied too much, because it reached 93 degrees. Then I applied a bit less(less than this), and still it runs hot (reaches 89). I'm testing it with Furmark. Here's how it looked like when I opened it. I'm pretty sure screws are nicely tightend. I haven't applied so much on memory(as seen on pictures(the paste up from CPU paste)). Should i do that? The gap between the cooler and memory is huge, like 3-4mm.
Before changing it was running on 83 degrees max.
Please help, thanks in advance.
