[SOLVED] Asus Radeon RX 6700 XT Issue wont start
imbakinacake
5
Hey everyone, I just finished helping my brother build his first PC but we've run into an issue.
BUILD:
Asus Radeon RX 6700 XT 12 GB ROG STRIX GAMING OC
MSI MPG Z490 GAMING EDGE WIFI LGA 1200 Intel Z490 SATA 6Gb/s ATX Intel Motherboard
Seasonic FOCUS GX-650, 650W 80+ Gold Fully Modular ATX
CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) 288-Pin DDR4 DRAM DDR4 3200
SAMSUNG 970 EVO PLUS M.2 2280 1TB PCIe Gen 3.0 x4, NVMe 1.3 V-NAND 3-bit MLC Internal Solid State Drive (SSD)
SAMSUNG 970 EVO PLUS M.2 2280 250GB PCIe Gen 3.0 x4, NVMe 1.3 V-NAND 3-bit MLC Internal Solid State Drive (SSD)
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz LGA 1200 125W Desktop Processor w/ Intel UHD Graphics 630
Refurbished: CORSAIR Hydro Series, H100i RGB PLATINUM, 240mm
Corsair 4000D Airflow CC-9011200-WW Black Steel / Plastic / Tempered Glass ATX Mid Tower Computer Case
Microsoft Windows 10 Home OEM 64-bit
After we got everything setup the computer wouldn't start, no LED's or indicator lights were on, except for the GPU, after reseating the RAM and unplugging the GPU from the PSU it booted and we were able to get windows installed from a USB using the integrated graphics on his CPU. At first I thought it was the RAM not being seated properly even though I knew that I had originally seated it 100% correctly, but when I plugged the GPU back into the PSU my system would no longer boot.... Well I messed with how the cables were setup and eventually got it to the point where now the system will boot with the GPU plugged in but nothing displays on the monitor. Currently I have one cord plugged into the PSU that then has a 2 headed end where both ends plug into the GPU (before I was using two separate cables and just leaving each one of the double ends plugged into nothing).
Any guess on what the issue might be? Having trouble installing the GPU drivers since AMD is not recognizing the card. I feel like it's something simple I'm just missing.
Thanks in advance for any help.
Thanks for the reply! I sure do, i have a 2060 and 1080 that i know are both currently working. What would be the best way to test? Put a good GPU in his PC or the "bad" GPU in mine? Or both?
Thanks again for the help.
Just uninstall AMD GPU drivers (you can use DDU if you like), turn off the PC, remove the RX 6700XT and then try any of those extra ones you have.
BUILD:
Considering the amount of high end hardware you are using I would have go with at least a 750 watts unit (could be same brand and model, just higher power).
As for your issue with the GPU, Im guessing the GPU is not working as intended. Do you happend to have any other GPU to test?
PSU should be sufficient and if power is connected from the PSU to the card it should work so most likely faulty card, to confirm that it would be best to try the card in another computer if possible.
Thanks for the response! I do actually have an old 1080 I can swap and try it out with. Will swapping the cards be as simple as uninstalling any graphics drivers or should it be recognized regardless? My brother is bring his PC to me later today and I'm just trying to get all my ducks in row, right now I'm leaning towards the GPU being defective, but sheesh, that just seems very unlikely to happen but I guess I've seen stranger things. A bad GPU would by far be the easiest thing to replace.
Right now my current troubleshooting agenda is
  • try different PCI slot
  • update bios
  • install graphics drivers
  • swap out GPU's and see what does and does not work
  • check CPU pins
