Hey ..
First this is my Motherboard ..
http://www.asus.com/ROG_ROG/RAMPAGE_III_EXTREME/
I know my questions might be silly .. i'm kinda clueless when it come to hardware ..
I have a Rampage 3 Extreme and and i just got a new Asus GTX 780 ( its the best available in my country sorry to disappoint you ) and tomorrow i'm going to re build my PC and install a new GPU and H105 CPU cooler so i thought i ask you couple of questions .
About the PCI-E slots ..
as what reviews says
I really don't understand a thing ..
i only want to install 1 GPU
my old GPU is already on the third slot ( from right to left ) ..
is that a x16 slot or not ? is it a must to install it on the first slot ?
this is a GPU-Z Screen Shot ..
Last question ..
check this picture ...
what is this adapter for ? i always have it plugged in but ive seen some people not using it at all, is it important ?
hope you guys help me out .. ive been googling these questions for 3 hours without any luck ..
The first PCI Express x16 slot works at x16 if the second slot is empty. If there is a video card on the second slot, both the first and the second slot will work at x8. The third and fourth PCI Express x16 slots work the same way: the third one works at x16 or x8, depending whether the fourth slot is empty or not. So if you have two video cards it is really important to use the first and the third (and not the second) PCI Express x16 slots in order to get the best performance possible. Using the manufacturer nomenclature, this motherboard supports the following configurations: x16; x16/x16; x16/x8/x8 or x8/x8/x8/x8. The slots are compatible with SLI and CrossFireX arrays.
Last question ..
