Question Asus Rampage VI Extreme Omega
Dec 31, 2019
49
6
45
Hi, I have a Asus rampage VI extreme omega board, it has 1xARGB header and 2xRGB headers, I have 2x EK D5 RGB Pump/res & 2x RGB waterblocks (CPU&GPU) and 6x Akira Vegas TLY ARGB fans. The Pump/res and waterblocks i have connected using spliiters on the RGB headers leaving me with just the 1 addressable rgb header from which i need to run 6 fans. I ordered a Silverlake LSB01 assuming i could run the fans off it but the connectors are not compatible and i can not plug the fans into it. any ideas how i could get all 6 fans to run off the one argb header i have? any help would be much appreciated
For anyone who falls into the same problem, the ROG Terminal works a dream, it can be used internally or externally (connect to usb header internal or usb port external) and gives you an additional 4 ARGB headers, i ran 2x 2 way splitters off 2 of the ports and then single connections on the other 2 plus i still have the ARGB header spare on my motherboard
