[SOLVED] ASUS ROG B450-F audio problem
Ij6969
72
So i just installed my new b450 f motherboard and for some reason i cant get my headphones to work on the front pannel connector. I know the problem is not the headphones or the hd audio cable its self because i tested it with a difrent motherboard. can someone help me trouble shoot this issue.
Do you have your motherboards Sonic Studio III software installed on your PC?
Is the headphone jack on the back I/O panel of your motherboards working?
Have you double checked the front headphone jack is plugged into the motherboard correctly?
https://rog.asus.com/forum/attachment.php?attachmentid=71943&d=1519735780&thumb=1
Yes I have both the software and drivers installed and the ports on the back of the motherboard are working. I have double checked many times to see if they are plugged in correctly. I have the nzxt h510 If it helps
