V vladicorp Distinguished Oct 22, 2012 38 0 18,530 Mar 14, 2019 #1 Hello, My monitor just switched to show the following. Do you think it is time to buy a new one of this can be fixed with some kind of reset ?
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Mar 14, 2019 #2 Try factory reset, if problem persists try a different cable/connection. If there's still a issue then it may be time to do a RMA with ASUS. Upvote 0 Downvote
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Mar 14, 2019 Solution #3 Try unplugging the monitor from power for a minute. Reactions: WildCard999 Upvote 1 Downvote Solution
V vladicorp Distinguished Oct 22, 2012 38 0 18,530 Mar 14, 2019 #4 Glenwing said: Try unplugging the monitor from power for a minute. Click to expand... That fixed the problem... Upvote 0 Downvote
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Mar 14, 2019 #5 vladicorp said: That fixed the problem... Click to expand... You'd be surprised how often it does Upvote 0 Downvote
