Question Asus RX480 weird temps problem
EpicFailSmile
11
Hello guys!
Ive got some weird temperatures problem with my Asus RX480 dual OC. My temperatures under heavy load started going up to 75-80 degrees celsius and about a week ago I was rarely seeing the card going up to 70 degrees. The cards stock freq. is 1300Mhz and stock voltage 1156 on that freq. I was always running the card at 1250Mhz max with a voltage of 1040mv. So even tho its undervolted and a little bit underclocked its still getting these temperatures. I changed the thermal paste several days ago, it didnt helped at all. I think I have a good enough airflow in my case and I havent changed anything inside the case before the problem occured. I have my fans running at 48% speed since going above that is too loud for me and annoys me. Oh and also im gaming at 75FPS since Im using 75Hz freesync monitor.
So what could cause the sudden temperature changes?
Thanks in advance!
