----------------------------------------My specs----------------------------------------
mobo: Asus sabertooth 990fx r2.0
gpu: vapor-x r9 280x
cpu: fx8320 (with evo 212 cooler)
ram: 16gb 1600mhz hyper beast
psu: seasonic x850
os: windows 8.1 pro 64bit
ssd: vertex 2 60gb
case: enthoo luxe, standard fans
This is a new build (except for my ssd), fresh windows install, so no conflicts with old drivers.
I didn't get this all together at once, but upgraded piece by piece from an old build. First mobo + ram, followed by cpu, followed by psu + gpu, followed by the case
----------------------------------------Audio problems----------------------------------------
So first problem, as described in title, problems with the audio jacks on my mobo.
The first thing I did was format my ssd, install windows 8.1
download all of the needed drivers for windows 8.1.
Updated the bios to the newest version
Installed graphic driver, audio drivers, nic drivers
Under the asus drivers I couldn't find the newest chipset drivers under windows 8.1, I found them under windows 7, and installed those. (they did list windows 8 as well).
I made sure the onboard audio is on and listed as hd instead of ac97
sometimes I get spammed with audio plugged in / unplugged messages. But even in the sound options to choose a default device, it always said speakers not plugged in,
sound through my graphic card's hdmi port to my receiver works fine, so does my logitech g35 headset.
Optical audio is listed fight (and shown as plugged in, even though it isn't). I only have digital out, yet shows two.
There's a total of 5 amd hdmi audio devices were only one is plugged in (I never had this with my old HD6870 vapor-x)
I don't really care about the audio atm as I run my hdmi to my receiver for movies / music, or use my headset for games. But I do have a normal audio cable running to my receiver which I'd like to use for music once in a while, ...
Reinstalled the drivers to make sure, didn't work either
Removed the device from device manager + uninstalled drivers, rebooted, wanted to see what windows drivers would do, but didn't work either.
----------------------------------------GPU problems----------------------------------------
Tried 14.4 normal, then the 2 new beta drivers
Running a benchmark for over an hour at full specs -> no problem
Played sniper elite 3 completly in one go -> no problems
Played Sacred 3 for 3 days -> no problems
Played the New Transformers game -> problems -> fixed with driver update from normal to beta
Tried to play older games like Assassin's Creed Brotherhood and revelations. Sometimes the display driver crashes and recovers, results in my game hanging.
I need to ctrl+alt+del, start task manager, alt+tab back in to the game, and I can continue playing. Sometimes this happens after a couple of hours. Sometimes after half an hour.
I've looked around on google, multiple sites, but couldn't find any solution that helped me out.
psu: seasonic x850
ssd: vertex 2 60gb
