ASUS Sabertooth Z87 won't power up
chords95
16
First post please be gentle, these are my components at the moment:
ASUS Sabertooth Z87
Intel i5- 4460
XFX 850w power supply
1TB sata HD
z1 Plus high performance case
89gb Ram
When i turn the power on the green SB_PWR light comes on but none of the case fans do and neither does any display on my monitor. I have double and triple checked all cables are plugged correctly, any help would be great thanks!
With Flashback you can.
Download the latest version from http://www.asus.com/Motherboards/SABERTOOTH_Z87/HelpDesk_Download/
Unzip and rename the SABERTOOTH-Z87-ASUS-2103.CAP to Z87ST.CAP
Save it on a FAT 32 formatted USB drive.
Connect the drive to the Flashback USB port (the one near the gray 3.5mm audio port - check the manual if not sure about its location).
Don't start the board, just make sure that the 24 pin power cable is connected.
Press the flashback button for 3 seconds.
Wait until the led stops flashing.
i cant update anything or change anything because nothing is coming on display, still no case fans working and nothing on the monitor, the only thing that has changed is that this little red cpu_led is coming on now
ive done as you said and downloaded the latest file and renamed it, although another file came with it called 'Bios_updater_for_4th_gen' do i need this on the usb also?
