[SOLVED] Asus TUF FX504 (i7-8750H) Power Limit Throttling (CPU stuck at 0.79GHz)
Jun 22, 2019
4
Hello, i have an Asus TUF FX504 gaming laptop with i7-8750H and GTX 1060 GPU. I heard that these models are kind of a pain in the butt but i didnt think it was that bad with the machine that i have. When i launch Aida64 or any other software the laptop drops the CPU speed to 0.79GHz at 36% utilisation. As you can imagine the games are unplayable. I have the latest BIOS, all of the fan and computer settings set to maximum performance, all of the drivers installed (even windows reinstalled twice). The only solution to this is to install ThrottleStop and to disable BD PROCHOT which then caps the CPU speed at 2.19. The temperatures are very low. What could be causing this?Anyone could share your experience with the same model?
I had this issue before but not on the same laptop. Mine was an asus gl502vmk with i7 7700hq. I used throttlestop to undervolt it and disable power limit throttling in throttlestop. It's working well now and cpu running at 3.4ghz (full speed) with 75 to 80C temps.
