Question ASUS Tuff B450 WOL ethernet not keeping power when shut down
loadyo
24
I bought an ASUS Tuff B450, i use it as part of a server running UNraid OS, if i shut the server down the light on the ethernet port (on board) goes out so it is not listening for packets, i have played with numerous settings, currently i have the following set...
wake from PCI event is enable
ErP is disabled
There are some other settings i have tried toggling...
PSU idle both settings
Global C state tried enabled/disabled and auto
The only way i can get the ethernet port to come to life in shut down state is to remove the power lead from it until all the risdual power has dissipated, when i plug it back in the ethernet light comes on and i am able to WOL, i can do it remotley over VPN but i need to be able to shut it down and start again remotley, obviously not possible if i have to unplug and replug it.
Anyone got any ideas ?
