Asus TURBO GTX1060 6gb stuck at 570MHz clock speed
Oct 22, 2018
I noticed an impact performance on my PC and looked into GPU tweak II and it showed that my clock speed for my GPU was at a maximum of 570 and a minimum of 570 (it said the same in MSI afterburner too).
I'm just looking for assistance with helping this as it regularly slows down my games and renders.
Screenshots of GPU tweak II and Nvidia control panel (3d thingy):
https://gyazo.com/97dc4e72cebfcc46ce1851cd0a3121ee
https://gyazo.com/d7031d63886625c61a9d35266cfadef7
https://gyazo.com/432660b0ed4c85b9b106fe9f79d9e9dc
https://gyazo.com/769a4eda254fb1aa3fd82fe7add58f2d
https://gyazo.com/e34e1e39dcde59e85f1a581e926bb318
Nov 8, 2018
6
Have you found a solution? I am having a similar problem with an Asus GTX 1060 Strix, mine is stuck at 810MHz, I haven't figured out a solution yet, maybe you fixed it, I'd appreciate if you have any info.
Oct 22, 2018
It isnt actually stuck just the ASUS gpu tweak II software is reading it wrong, download another software to check the speed, once i get back to my PC i will give you the one i found and it should all be running smoothly, but make sure in you NVIDIA 3d settings is set to max performance in power settings x
