Asus u52f will not boot, power light comes on but the fan or hard drive does not
Itsj5
5
I am currently working on a Asus u52f laptop for a customer of mine. My mind is shot and I don't have a lot of resources. I plug the power source in and push the power button, the power light comes on but nothing else does. No fan no sounds/sign of the HD, no beeps. The screen does not come up, nothing. I have tried pulling the battery and unplug the machine and hold the power button for X amount of seconds. I tried removing ram, switching, one at a time etc. I searched google for answers and just haven't gotten anything. I took the machine apart and looked at the motherboard no signs or damage(however I didn't take the motherboard completely out to check the other side) I don't want to waste to much more of my time trouble shooting this machine for I have other work to do. My best guess though is the motherboard is shot and I will have to replace it. However I don't want to go but this part replace it and have it still not work (no one does). Anyone have this problem before or has a definite solution? Thanks!
jarotech
Dignified
Oct 13, 2012
3,927
654
If you want to repair the laptop you must follow some guideline to troubleshoot the problem. You don't want to take much time to troubleshoot the laptop so give it to a laptop repair shop. There is no definite solution to any problem.
Itsj5
5
I will go through the trouble shooting process I already have done a lot what I am asking is can anyone point me in a direction to fix this laptop I have done things already (listed above) there can be definite solution to a problem if someone has experienced the same problem. Do you have any idea what could be wrong?
Itsj5
5
I'm going to try removing the battery to see if this works...I will let you know the results
samIam1
I am having the same issue, what battery are you talking about, I have moved my battery a zillion times and it does not do a thing, let me know please,thanks.
jarotech
Dignified
Oct 13, 2012
3,927
654
Hi, don't say you have the same problem, each problem don't have the same answer. Make another thread with all the informations needed for your problem, and someone will respond with the right answer.
Similar threads
