ASUS USB 3.0 Front Panel Box Problem
deertroy1
61
I have an ASUS P8P67Pro motherboard. I purchased an ASUS USB Front Panel Box and connected it to the 19 pin header on the motherboard. My problem is that when I plug my WD MyPassport into it it doesn't get recognized. The power light does come on though. If I connect it to the USB 3.0 port on the rear of the board it works fine. If I connect my Seagate USB 2.0 Free Agent to the Front Panel box it also works as it should. I updated the Renesas driver but still no go. I also do not see the additional USB 3.0 ports showing up in device manager. Any thoughts?
leinad1
Check your BIOS to enable the Onboard USB 3 header. Also check under Computer Management/Disk Management to see if it shows up there
