kloutkobain :
Barty1884 :
Screen "tearing" or a defect? If you're experiencing "tearing" in game, capping a framerate would help.
Yeah I've done that and even capped it below 75 fps and even at 60 fps with 75hz on and still no fix.
Capping the FPS doesn't get rid of screen tearing even if the FPS matches the monitor refresh rate. You need to enable VSYNC to get rid of screen tearing. VSYNC results in an FPS cap that matches your monitor refresh rate but it's synchronized in order to prevent screen tearing (new and old frame data mixed with same refresh).
VSYNC advantage is no screen tearing.
VSYNC disadvantage is added lag (a bit more sluggish).
When you do that it's best to configure the game settings so they rarely dip below that FPS...
