S spotify123amund Prominent Aug 19, 2017 1 0 510 Aug 19, 2017 #1 Ive had this monitor a couple of months and now it has a white stripe under the middle of the monitor. Ive tried it on another computer and it is still there. I use dvi dual link. Hdmi has the same results
Solution bignastyid Aug 20, 2017 Likely a bad panel. If it was bought new it should have a 3yr warranty. Contact Asus to RMA it.
bignastyid Titan Moderator Jun 19, 2011 33,688 1,700 159,590 Aug 20, 2017 Solution #2 Likely a bad panel. If it was bought new it should have a 3yr warranty. Contact Asus to RMA it. Upvote 0 Downvote Solution
