ASUS VG248QE Problem
Steverism
79
Hi guys, so I have a problem that just started appearing suddenly. If I move my monitor, even at the shortest little distance, my monitor has green pixels all over it, it can either go from a LOT to a little depending on how you position it. I'm using the Daul-Link DVI Cable that came with it. Sadly, I can't take a picture of the problem as I've already tried and it comes out normal. So, what should I do, buy a new cable?
It sounds like the cable might be the issue. It is possible that the connection to the Monitor could be an issue too, but I try new cable first, since they are pretty cheap. You could also use a different port on the Monitor (HDMI, Display Port, etc.) which you have on that monitor.
Another thing I forgot to mention is that I have my second monitor which is an old 60hz monitor, hooked up to the same PC with an HDMI cable, so, surely its the cable?
