News Asus will showcase Ryzen AI 300 laptops on July 17 — Ryzen AI 9 HX 370 and Ryzen AI 9 365 to power TUF Gaming, ROG Zephyrus, Zenbook, and ProArt se...
The ROG Zephyrus G16 GA605 has four variations using the identical AMD Ryzen AI 9 HX 370 processors and GeForce RTX 4060. However, its comparison at the time of writing does not show the difference between all four variants.
I'm sorry. That's not correct. Here is the actual config. One supports the RTX 4070 GPU as well.
The ROG Zephyrus G16 will be available in ONLY two configurations.
  • The ROG Zephyrus G16 (GA605WV-XB96), Platinum White, boasting the latest AMD Ryzen AI 9 HX 370 processor, AMD Ryzen AI XDNA 2 NPU, a GeForce RTX 4060 Laptop GPU, 32 GB of LPDDR5X-7500 RAM, and 1 TB of storage will be available starting from $1,899.
  • The ROG Zephyrus G16 (GA605WI-XB96), Eclipse Gray, boasting the latest AMD Ryzen AI 9 HX 370 processor, AMD Ryzen AI XDNA 2 NPU, a GeForce RTX 4070 Laptop GPU, 32 GB of LPDDR5X-7500 RAM, and 1 TB of storage will be available starting from $2,299.
The ProArt P16 H7606 has a 3840 x 2400 16:10 OLED display with up to 60 Hz refresh rate but does have a touch screen with stylus support. It does not have a rotating hinge, and graphics options are limited to the RTX 4070 and Radeon 890M graphics.
No.
This Laptop comes in 3 different configurations, with RTX 4050/4060/4070 as the discrete GPU options. Since it also supports the AMD Ryzen AI 9 365 processor, then it means support for 880M RDNA 3 igpu as well !
Reactions: KnightShadey
