Hello. how are they? I have a problem to see if you can help me.
My setup:
Asus x299 TUF Mark2 motherboard (Bios recently updated to the latest version (3601))
Ram Team group (2x 8gb ddr4 3200).
Intel i5 7640x microprocessor.
Sentey power supply 1000 bronze.
I bought a microprocessor intel i9 7900x
CONFIDENTIAL QLRX 2.4GHZ
C648A688
D6E266W500176.
Today the card is mining with 4 video cards on risers. These cards are:
asus 3070
gigabyte 3060ti
aorus 1080
asrock vega 56
When I install the i9, the vga Q-led (white) stays on and it doesn't boot. I tried to place only one card in riser in all the pcie and nothing. I tried with all the cards in risers and nothing.
I tried with the all vga directly on the motherboard (without riser) and always the same error.
I put the i5 back in, and everything is back to normal (works).
update the bios. change the ram, try with another power supply and the same result. provided that the i9 is placed. q-led VGA white led on
"the i9 I bought was working."
It should be noted that the micro i9 7900x is within the asus support page, that is, my x299 tuf mark2 SUPPORTS that cpu.
suggestions??
My setup:
C648A688
D6E266W500176.
asus 3070
gigabyte 3060ti
aorus 1080
asrock vega 56
suggestions??
