I have a x470-f mobo control panel issue I believe. My psu and other stuff isn't the problem as I tried those with other pc build and the pc boots. I tested this with the bare bones (cpu, psu,mobo, fan) The manual tells me this for the control panel: (image credit --> raisonjohn)
/url]https://gzhls.at/blob/ldb/f/1/b/5/e8796cb33bd62a0da7a5d42624cdc19c2401.pdf
[o][o][o][o][x][o][o][o][o][o] [1][2][3][4][x][o][o][o][o][o] (speaker plugins to the right of 4)
[o][o][o][o][o][o][x][o][x][o] [o][o][o][o][o][o][x][o][x][o]
* where: o = pins; x = no pin
Manual states most top left corner are front panel LED + (1) and - (2), and the next one (3 from top left corner) is the power-sw and (4) ground. Now when i tried that, my pc doesn't boot and no LED on front panel. I eventually tried the front panel LED+ and LED- on (3) and (4) and the LED on the front panel works. Not sure what to do with the power-sw connector since it doesn't seem to work on the other pins. Do you think the mobo control panel was improperly produced or could there be other issues to why pc won't boot.
If you think there is a solution, please let me hear it
