Hello
I have recently received from a friend a laptop that will not boot into Windows. The laptop is running Windows 8 from what I can tell and the model is an ASUS X551C.
I asked what had happened. They said their daughter was watching a youtube video and it stopped playing and they shut down the laptop.
Since then it has not worked properly.
Upon powering the laptop up a blue screen appears reading:
Recovery
Your PC needs to be repaired.
A required device isn't connected or can't be accessed.
Error code: 0xc0000225
You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a a disk or USB device), contact your system administrator or PC manufacturer.
Press Enter to Try again
Press F8 for Startup Settings
Press ESC for UEFI Firmware Settings
Pressing enter brings the same screen back except it says:
File:\\Windows\system32\winload.efi
Pressing F8 does nothing.
Pressing ESC takes me to the BIOS.
I have tried to press F9 during bootup to see if the laptop will launch its recovery partition but nothing happens.
I have created a Windows 8 bootable thumbdrive from another desktop PC.
Using the thumbdrive I have tried:
Startup Repair choosing Windows 8 as the targeted system. It goes through "Diagnosing your PC", followed by "Attempting repairs", followed by a blue screen saying Startup Repair couldn't repair your PC. Press "Advanced options" to try other options to repair your PC or "Shut down" to turn off your PC. Log file: \System32\Logfiles\Srt\StrTrail.txt.
I have tried System Restore choosing Windows 8 as the targeted system. A dialog box appears saying System Restore could not find the offline boot volume. Please ensure it is currently accessible. Close. Upon closing a new dialogue box appears saying "There was an unexpected error: The parameter is incorrect. (0x80070057). Please close system restore and try again. Ok.
I try to reset this pc option. I first choose the option Keep my files. Choose Windows 8 as the targeted system. After selecting this option a new screen appears saying "The drive where Windows is installed is locked. Unlock the drive and try again."
I try the option reset this pc remove everything choosing Windows 8 as the targeted system. The next screen appears saying Unable to reset your PC. A required drive partition is missing.
Using a command prompt from the recovery media and the diskpart command I am able to select Disk 0
Upon listing the partitions I see the following:
Partition 1 Reserved Size:128MB Offset: 17KB
Partition 2 System Size: 100MB Offset: 129MB
Partition 3 Recovery Size: 900MB Offset: 229MB
Partition 4 Primary Size: 677GB Offset: 1129MB
Partition 5 Recovery Size: 450MB Offset: 678GB
Partition 6 Recovery Size: 20GB Offset: 20GB
Hoping for some help because at this point I am not sure what is going on.
Recovery
