D docdct Commendable Jul 26, 2016 3 0 1,510 Jul 26, 2016 #1 Asus laptop x553m has no indicator lights, no power, no boot but power adapter is good as we tested it with a meter. Jack is not loose either. Will a bad / dead battery cause no indicator lights?
Solution hang-the-9 Jul 26, 2016 A dead battery should not prevent a lapotp from booting on wall power, but a dead motherboard would. Try it without the battery.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Jul 26, 2016 Solution #2 A dead battery should not prevent a lapotp from booting on wall power, but a dead motherboard would. Try it without the battery. Upvote 0 Downvote Solution
D docdct Commendable Jul 26, 2016 3 0 1,510 Jul 26, 2016 #3 hang-the-9 : A dead battery should not prevent a lapotp from booting on wall power, but a dead motherboard would. Try it without the battery. Upvote 0 Downvote
D docdct Commendable Jul 26, 2016 3 0 1,510 Jul 26, 2016 #4 That's what I thought but wanted another opinion. Did unplug the battery with no difference, no power and no lights. Oh well. Thanks for the reply! Upvote 0 Downvote
