I read up on the place to connect the fan card but there is no good instructions as to where to attach this thing to the case-a Corsai 500R alot of people seem to have a problem wiht this attachment point-any ideas?
It is installed in a 5.25" drive bay. Connection is 4-pin molex from power supply and 3-pin or 4-pin fan connections.
okay I did get the fan controller car with the x99 deluxe Asus mobo but there is also a fan control switch on the Corsair 500R case on the front panel-so is it better to just skip that and use the fan card that came with the mobo.there is supposed to be some kind of fan management system software for the board so that would control the fans from the card-am I right??thanks again
