Asus Xonar Essence STX very quiet at max volume
Kuxx
Just bought a STX made sure the power was plugged in firmly and made sure it was seated properly. The card came with a Y cable that you plug into both RCA ports for my speakers, plugged that in, and at normal volume I get no sound at all. At max volume it sounds like I have my speakers a little less than halfway up. I've also disabled my onboard sound. It is even worse when headphones plugged in. Any ideas?
I have the latest Uni drivers installed. And on the eq it says none. Not sure how to change those settings.
