ASUS z-87 Pro ethernet issues
inducedreaming
14
I have downloaded the ASUS drivers for ethernet and it only gives me 100Mbps but if i use wi-fi i get 144.4Mbps
Surely my ethernet can go faster??
inducedreaming
14
I have installed the I217-V LAN driver from the ASUS website but it makes no difference
I was thinking there might be something in the device manager that I could change, perhaps in the properties?
It just seems odd I get a faster connection with Wi-fi
inducedreaming
14
I dont know if anyone is reading these but:
I looked on the EE website: http://help.ee.co.uk/system/selfservice.controller?CONFIGURATION=1016&PARTITION_ID=1&secureFlag=false&TIMEZONE_OFFSET=&CMD=VIEW_ARTICLE&USERTYPE=1&ARTICLE_ID=540791
I changed the wireless to this dual channel 20/40 Mhz business
I have:
My ASUS double antenna giving 144.4 Mbps
My D-link N booster dongle giving me 130 Mbps
AND
Direct line from my Intel ethernet reading 100 Mbps
Which ones should i turn off?
I can change the settings of the Intel 217-V ethernet to 1 Gbps (full duplex) but then the LAN connection disappears
CAN SOMEBODY PLEASE HELP?
phunny12000
8
those rates are the rates theyre capable of,nd your mobo has the very latest wifi.your ethernet 100bs is the same standard as it has been for yrs.
theyre both a lot faster than your network.
i,d disable the wireless ones and leave the hardwire connected,
