This is the SECOND new MB problem this week. I am building 2 new systems, the first is an ASUS H170 MB and it is arriving Tuesday from ASUS , TS did an upgrade to the BIOS because the DRAM LED stayed lit. We shall see if that fixed THAT problem.
The second MB is an ASUS Z170-A, and this one has the BIOS LED staying lit red. When powering up, all the LED's go through sequence OK (Red to OFF) but BIOS LED stays lit.
The systems is using the proper (AVL DRAMS for this board), the CPU is and Intel i5 6600, I have a video card but I am using the on-board video to eliminate the VGA as a possible issue. All fans works Ok, no sound so I cannot use beep code. No HDD's or SSD's are connected yet to eliminate that as a possible problem. No video on the tested working monitor using DVI cable input to MB.
Seeing that I now have 2 ASUS new MB's from Newegg.com that exhibit the very same issue, no video, no post, is it possible that both need upgrades to BIOS? What gives with all these MB's having POST problems lately? I have built 5 systems since 2010 and have NEVER had one MB have an issue until 2016.
What is causing the BIOS LED to stay lit when all other systems check OK (LED's) on power-up ? Can the BIOS's need upgrading that soon to be this critical that the system will not Post ???
