Asus Z170 Pro Gaming 8-pin ATX12V Issue
SilviuParvu
Commendable
May 20, 2016
5
After finishing the PC Build, the motherboard's LEDs will turn on, but the PC itself won't start. But if I plug out the 8-pin ATX12V connector, the motherboard LEDs, the chassis fans and the GPU fans will all start, and again the PC won't turn on. Any idea how to solve this problem?
PC Specs:
Intel® Core™ i5-6600K
Corsair Vengeance LPX 16GB (2x8GB) DIMM, DDR4, 2400MHz, CL16, 1.2V, XMP 2.0,
MSI GTX 970 GAMING OC 4GB DDR5
HDD Seagate Barracuda 1TB, 7200rpm, 64MB cache, SATA III
Cooler Master Hyper 212 Evo
Actually, I think I may have put 2 4-pin PCI-E connectors there too. 1 fit fine, but the other was the wrong shape. I plugged both in and the board is running fine. I've found 3 other 8-pin cables in the PSU box that WILL fit properly. They are labelled CPU, AE04 and AE09. Can you tell me which one I should use..?
