Hello everyone,
I'm currently in the process of building my first PC, and as the title suggests I'm using the Asus Z170I Pro Gaming motherboard. My build was all going to plan, however I seem to have hit a brick wall. I'm stuck on where the front i/o panel connectors should go. So I need some help.
These are the cables coming from my front i/o panel:
And this is the diagram for the system panel connectors from the motherboards manual:
Now I assume the H.D.D. LED and Power LED connectors just connect to the H.D.D. LED and Power LED connectors on the motherboard? But would it be negative to negative and positive to positive, or negative to positive? What about the Power SW cable? Does that connect to Power BTN or Reset? Also what does the little arrow/triangle on the connectors stand for?
