Drummermandan87 :
Hi,
I have very recently built a new Haswell based PC and I am using the Asus Z87-Deluxe as my mainboard. The build went pretty smoothly, however after installing the WiFi/bluetooth drivers to enable the inbuilt Broadcom 802.11ac wireless adapter to function I could only connect to my wireless router with 'Limited' connectivity.
I am running Windows 8 64-bit and understand that various things can cause 'Limited' connection. So I tried all the known solutions available like, disabling the adapter power management option and resetting the TCP/IP stack but this did not solve the issue. After reinstalling the lastest drivers countless times (older drivers caused the WiFi adapter to not pick up wireless signals at all) and reinstalling Windows, the problem was still present so I decided to contact Asus.
An Asus technical adviser suggested that I RMA the motherboard as it might be a faulty wireless adapter. I fitted the replacement board yesterday and fired up the computer to initially find that the wireless worked! However I could only connect to the 2.4 GHz band on my router, the 5GHz band again showed a 'Limited' connection. However, this morning I tried connecting the 2.4GHz radio resulting in the dreaded 'Limited' connection again.
This is a second board with the same problem, so I am unsure if it is a hardware fault or a driver problem. I just wonder if anybody has had this kind of problem with this type of motherboard and if they have any suggestions. Unless it is a problem with my setup which is listed below:
MB: Asus Z87-Deluxe (The lastest 1405 Bios)
CPU: Intel 4770K (@ stock speed)
Cooler: Corsair H100i
Ram: G-Skill 8GB (F3-17000CL11D-8GBXL)
SSD: OCZ Vertex 4 256GB
SC: Asus Xonar DX2
PSU: Corsair CX750M
OS: Windows 8 64-Bit
Sorry for the long post, but it would be great if anybody has any information or suggestions before I contact Asus again or pick a new board - it just seems strange that two brand new boards could have the same issue!
Cheers,
Drummermandan.
RealBeast :
Drummermandan87 :
Hi,
SC: Asus Xonar DX2
PSU: Corsair CX750M
Cheers,
Drummermandan.
Did the late November driver update for Windows 8 fix the issue?
I had the "same" setup and the "same" experience as The Drum. I believe my firmware update was October, however, it was the latest available through Asus. NOTHING WORKED to properly activate the To Go modem. For the first few days, I had NO CONNECTION AVAILABLE and Limited Condition, and then I had a connection which was the same speed as in that old Xerox commercial in which reams of documents are copied by scribes. I spent a week on Wi-Fi , not believing that it was possible that I could not determine the fix. (I was confident that it was not a hardware issue. I also ignored my Universal Truth - That if you reach a dead end during a build, call someone that knows the answer. The problem here was it was an Asus only issue re: the unknow modem and I didn't want to deal with customer support who was going to take the easy way out - RMA the board, so I can have the same problem with the new board since it didn't seem to be a hardware issue).
I did so many things that i cannot attempt to list them, except for what eventually worked, as follows:
1. Right click on the Wi-Fi icon in your tray and then select Modify Adapters (or equivalent command). Mine is a Qualcom while you show yours as Broadcom. Interesting? Right click on it, and Disable it. If Uninstall is an option, use that. So now you are left without a modem.
2. Reboot.
3. Insert your Z87 MB disc. I know you already selected Install Asus (or equivalent command). Instead, now select only the Bluetooth and Wi-Fi command. You might have assumed that your "drivers" were properly installed with the general installation that gave you a checkbox list of what you wanted installed. Somehow the singular selection is different and you get different screens. I really cannot recall what they are but just follow the easy steps.
4. Next, reboot your computer after removing the Asus Disc. You should end up with the modem being located. Again I cannot recall but you may have to right click on it (see above) and Enable it.
5. That fixed the issue for me. While you might assume that Asus provided you with an installation button for all the selected drivers in their list, that does not appear to be the case with the modem. I then went back through each topic, such as the Intel Storage Technology for SSD. Make certain that each of the subcategories from that general installation is really installed and activated.
One remaining issue - now you are thrilled about having this new modem which appears to be an 801.ac installed, your router is still going to bog down your new computer's Interent use. If you had a decent dual channel 801n modem, you have not gained any speed. Also, as I transfer files across my private network, I note those messages that the transfer will take a day. The router's limitations apparently raises its ugly head again. I guess we were short $200 for the router, and about $50 if you need to pick up some internal/external hard drive cards. IF I COULD FIGURE OUT HOW TO USE THE BROWN SATA ports (whatever the name of the controller is), I would be set. So far I can't find much information. The Asus Manual is mum on the subject. They merely copy the same language from the yellow SATA port section. With the brown ports I could hook up my already installed 2nd optical drive and add a 6th HD. (1) OCZ 120 to boot; (1) Built-in SATA Memory card reader; (1) 3TB HD; (2) 2TB HD; (1) Samsung 840 to load with a few of the biggest and slowest loading programs such as Acrobat, Libre Office Dev. version; AVG, Malwarebyte, multitude of cloud storage programs (I pay for 2 unlimited ones but I just can't decide how to limit it to one with all the tablets and iphones, laptop, 3 desktops. Pay for Carbonite and Bit Casa. Still have difficulty with conceptualizing mirroring, incremental backups, moving files to a copy drive rather than right clicking them etc. They seem to have duplicate functions - why do you have the option to MOVE your folder rather than right click the folder and leave it where it is? And how can some of the other apps still use FILES rather than folders?
Can someone explain to me how I can use the Marvell controller SATA ports for a hard drive? for an optical drive? In the BIOS those SATA drives do not even appear (at least in regard to boot-up priority. I can at least understand the conclusion that they cannot be used for boot-ups (?) but how do you make use of them.
We need to form an International Convention on Manual Writing and Translation. Groups of people should have to handle a build using the Manuals, recording the questions and comments made to the tech people who will need to be bused in.
I keep staring at the HAF 922, ready to close it up. Is the cable maintenance sufficient? Will the back side of the case ever close with all those cables stuffed back there? Is there anything else left to do, as I find some issue in the Asus installation disk every day. Do I use the Optimal settings in the BIOS and call it a day for now, and overclock further on a later date? Is there any more Enabling or Disabling I need to do? I found that some defaults seemed to set set in a manner that didn't seem to be recommended by the software's on-screen comments. Do I move on to the theater-like hook up and worry about new or different issues later. What if someone explains how to make use of the Marvel SATA ports the moment after I stuff the cables into the case.
