I built the PC with an Asus Sabertooth Z87 mobo, i7-477K, Corsair H100i liquid cooler, and the H100i cooler. The cooler radiator assembly has two fans, and the case has front, side, rear fan, and two small fans are built into the mobo shielding to blow air over the mobo components. After booting up and running AI suite to optimize fan control, all of the fans ran at a relatively low RPM and the Unit made very little noise. That was before I flashed the bios. After that, the H100i cooling fans run at full speed. Even when set to silent mode, other fans in the case turn down or completely stop, but the H100i fans keep running at top speed. Does anyone know what the H100i fans won't slow down again? The components on the mobo including the video card (MSI R7950 twin frozr III) barely even get warm under load. I've already un/reinstalled the asus AI suite and recalibrated the fans, several times.
