B blakef223 Reputable Mar 28, 2014 19 0 4,520 May 5, 2014 #1 Hello, im trying to complete my build and install the drivers for my Asus z87 pro mobo using win 8 64 bit but when i download the driver from the asus site they arnt working, any tips on how to get this to work?
Solution Dark Lord of Tech May 5, 2014 They are zip files did you open them. http://www.7-zip.org/ Open with this ^
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 5, 2014 #2 What do you mean ain't working? Upvote 0 Downvote
RazerZ Judicious Ambassador Aug 18, 2013 9,961 0 33,960 May 5, 2014 #3 What do you mean ain't working? I was about to say the same thing lol Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 5, 2014 Solution #4 They are zip files did you open them. http://www.7-zip.org/ Open with this ^ Upvote 0 Downvote Solution
B blakef223 Reputable Mar 28, 2014 19 0 4,520 May 5, 2014 #5 Yeah i downloaded all the drivers and everything is now working except the drivers for the wifi go module. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 5, 2014 #6 Do you have the ASUS AI Suite III installed. Upvote 0 Downvote
B blakef223 Reputable Mar 28, 2014 19 0 4,520 May 5, 2014 #7 Yeah AI suite is installed and but wifi go doesnt show up in the menu Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 May 5, 2014 #8 Do you have the antenna installed? Upvote 0 Downvote
