I recently purchased an Asus Z87-Pro (V-Edition) and several other parts to build a new PC.
Among the parts are memory DIMMs G-Skill F3-14900CL9Q-16GBZL which is listed as compatible with the motherboard.
After building the system, the machine apparently doesn't post, and displays a Q-code 55 (Memory not installed).
I've tried reseating the memory several times, and even installed each Dimm alone to see if it was there was a bad module.
Is there something I'm missing? Or is this an more issue with the motherboard or memory (that I should return)?
