Asus Z97-A MOBO red flashing CPU_LED no POST
tomsly
Hello,
I'm helping my friend put together his PC. We are experiencing a stop and start with attempting to POST the PC. The red CPU_LED light flashes when we power up.
After trouble-shooting I have found only this....
When the CPU plug is disconnected from the MOBO the GPU works as does the CPU cooler fan and case fan. However, once I plug the 8 prong CPU cord in it gets the stop-start and red CPU_LED light.
I have tried multiple things to attempt to fix the issue and nothing has worked:
1. We have replaced the MOBO and CPU with brand new ones (ASUS support recommended.)
2. I have swapped my PSU that I have on my PC with his PSU and still get the same exact issue.
3. Tried different RAM slots, no RAM.
4. Bare minimum MOBO powered up with no extensions plugged in.
Here are the specs:
(We are just using the stock cooler at the moment as well.)
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($226.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($129.99 @ Amazon)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($67.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive ($79.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($328.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($107.99 @ Directron)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($65.99 @ Newegg)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($113.25 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse ($79.49 @ Amazon)
Headphones: Logitech G430 7.1 Channel Headset ($54.49 @ Amazon)
Total: $1324.94
Generated by PCPartPicker 2015-11-04 10:24 EST-0500
Going to try that, I updated the post with specs, any more opinions would be great!
alexoiu, I actually took my tower over to his place and tried my PSU and got the same response, with the CPU cable plugged in vs unplugged. Should I still take the MOBO out of the case and try?
