I have just built my first ever pc. I have connected everything up and just plugged the power on. Everything seems to work fine as far as I can tell except there is no image on my screen. I've tried using HDMI and VGA. Please help!
what specs do you have.!? if you have a dedicated gpu use the inputs it provides to connect to monitor. if you dont have one and you are using the mobos inputs, you must have an cpu with intergrated graphics!
Thanks
Having a few teething problems so far like trying to install Bullguard makes it just completely freeze and stuff... I am wondering how stable the SSD is as I've heard the EVO 840 can sometimes be sketchy... hopefully that isn't the case and it will sort itself out. Keep getting machine_check_exception.
about the error you keep getting and since thats a new build, run memtest with one stick at a time. ensure cpu / gpu temps are with limits, try coretemp / gpuz . also if overclocked make sre it is stable! lastly check your ssd with HD tune . doing all these will help you distinguish between software and hardware related issues.!
