Asus Z9PE-D8 WS problem ( Not working )
sagitarius_2k
9
hello all
Mine mobo cannot booting to bios. Plug everything to PSU, and when i start it, the fans and PSU not working, but LED is light up. But no q code whatsoever on those.
Is there something wrong? or i forget something to start it up?
thanks
Clear CMOS, check UEFI and CPU support list to check if your CPU is supported and see if you need UEFI update. If not that, not sure what the problem is.
Hello mr Raja
yes, i do that exactly you say.
Double check PSU : all 24 and 2x8 are in
CPU bents : try with different xeon
Board against case : first thing to do
anything else ?
