Hello,
I'm trying to install two Asus ZenWifi Ax Access Points and I have nothing but problems!
During the first installation, everything worked normally and easily with speeds close to 500 Mbps near the two terminals.
But, a few hours later, the second terminal did not reach speeds lower than 50 Mbps to reach today ... less than 1Mbps!
At first, to try to solve this problem, I separated the 5Ghz and 2.4 GHz networks and connected my devices going on the internet in 5Ghz. This worked for a few hours to have again very low speeds on the 2nd terminal.
I would like to start again from scratch but I can't manage to reset one of the two terminals to factory settings. I can reset the one connected in WLAN thanks to the application, but I can't reset the second one and I can't find reliable information on how to do it.
I read that you have to unplug the terminal and press the WPS button for several seconds while waiting for the LED to turn red: the LED never turned red.
I tried unplugging the terminal and plugging it back in while pressing "in the hole" under the base of the terminal: the LED turned red, but it never blinked and never came back blue, indicating that the reset was successful.
Does anyone know the RIGHT way to reset these bollards?
And does anyone have an explanation for the flow problems that are getting smaller over time?
Thank you for your patience, if you've read this far!!!!
Translated with www.DeepL.com/Translator (free version)
