[SOLVED] ASUS Zenbook - The left control key works for Control+Alt+Delete but not for copying (Control+C). Any ides why and how to fix?
dolokhov
56
As the title says, the keyboard doesn't recognize the copy binding (although it works when I use the right side control key).
I feel like I've fixed this in settings before, but I can't remember where.
Any ideas?
Try a clean boot and see if it changes anything - make sure to read instructions and make sure NOT to disable any microsoft services or windows won't load right - https://support.microsoft.com/en-au/help/929135/how-to-perform-a-clean-boot-in-windows
that will tell you if its a conflict
if clean boot fixes it, it shows its likely a startup program. You should, over a number of startups. restart the programs you stopped to isolate the one that is to blame.
Colif
Win 11 Master
Reactions: dolokhov
