R RazerSharp7 Prominent Mar 22, 2017 28 0 530 Nov 24, 2017 #1 Hello does the asus zenith extreme motherboard fit in the cougar conquer if not please recommend a motherboard for amd threadripper Thanks
Solution bjornl Nov 24, 2017 Your MB will not fit in that case. It is a EATX motherboard and an ATX case. Since you like that brand here you go: PCPartPicker part list / Price breakdown by merchant Motherboard: Asus - ROG ZENITH EXTREME EATX TR4 Motherboard ($374.99 @ Amazon) Case: Cougar - Panzer Max ATX Full Tower Case ($149.98 @ Newegg) Total: $524.97 I added your motherboard, though I know you don't need it. It is so that you can click on the link and explore other eatx cases.
bjornl Honorable Mar 16, 2016 2,962 2 10,965 Nov 24, 2017 Solution #2 Your MB will not fit in that case. It is a EATX motherboard and an ATX case. Since you like that brand here you go: PCPartPicker part list / Price breakdown by merchant Motherboard: Asus - ROG ZENITH EXTREME EATX TR4 Motherboard ($374.99 @ Amazon) Case: Cougar - Panzer Max ATX Full Tower Case ($149.98 @ Newegg) Total: $524.97 I added your motherboard, though I know you don't need it. It is so that you can click on the link and explore other eatx cases. Upvote 0 Downvote Solution
R RazerSharp7 Prominent Mar 22, 2017 28 0 530 Nov 24, 2017 #3 bjornl : Your MB will not fit in that case. It is a EATX motherboard and an ATX case. Since you like that brand here you go: PCPartPicker part list / Price breakdown by merchant Motherboard: Asus - ROG ZENITH EXTREME EATX TR4 Motherboard ($374.99 @ Amazon) Case: Cougar - Panzer Max ATX Full Tower Case ($149.98 @ Newegg) Total: $524.97 I added your motherboard, though I know you don't need it. It is so that you can click on the link and explore other eatx cases. thanks, going to go with i7-8700k now Upvote 0 Downvote
bjornl Honorable Mar 16, 2016 2,962 2 10,965 Nov 24, 2017 #4 RazerSharp7 : thanks, going to go with i7-8700k now That would be my choice too. The threadripper is cool, but it is sort of a specialized tool. Upvote 0 Downvote
