Question Asus's 3080 3x 8pin PCIe Power supply question
Sep 4, 2020
6
Hello,
so the new GPUs are coming out and i am currently considering the 3080 as a fine upgrade to my older card. I am currently using this PSU:
https://www.chieftec.eu/en/psus/ps-2/navitas-series/gpm-1000c.html
It only has 2 PCIe 8 pin connectors, while the 3080 of Asus will need 3.
So i am considering buying a new PSU which supports 3 or in the worst case use an adapter for 2x Molex to PCIe but i dont think that is safe, considering that 12,5 A would run through a few thin cables. Do you think the PSU can handle it? Its rated for 1000W with an efficiency at 90% (its 4 years old now, so probably going down to 80% or so).
I asked Chieftec through mail, they say its safe if i use one of their adapter (Of course they would, they wanna sell stuff). Hoepfully someone is a bit more tech savvy in terms of PSUs here and can help.
If not can you suggest a few PSUs that would be good enough? Price range doesnt matter for now, although preferably below the 200€ mark.
Sep 4, 2020
6
DO NOT USE MOLEX TO PCI-E adapters. If your PSU does not have the proper connections you need a new PSU.
Well yeah, thats what i read everywhere. Do you have suggestions about PSU that would be good enough? System currently is a maximus hero x, 8700k, 3200 Mhz ram, a few SSD/large HDD and a 1080 strix OC.
DSzymborski
Polypheme
Actually, while good Chieftecs are a rarity, this was on a higher performing CWT platform, the same as some of the Thermaltake Toughpower Grands. If this is the PSU you have, yes, it has two PCIE 6+2 cables in the built-in portion, but it's also supposed to come with modular cables for four additional PCIE 6+2 connectors.
If the modular cables are lost replacing them may be a pain; this isn't a popular brand/platform for aftermarket cables (and remember, modular cable pinouts are not universal on the PSU side).
Sep 4, 2020
6
Yes, it should but did not. The guy from Chieftec said that this might be because they produced two versions and i might have gotten one of the older ones that were running out (short straw i guess, did not even know that).
I am currently looking through a few PSUs that sound good like:
https://www.bequiet.com/en/powersupply/1767 and its 1000W version (for extra leeway)
But also some from ASUS themself like:
https://www.asus.com/uk/Graphics-Cards-Accessories/ROG-THOR-850P/
anything to add or remove here?
edit: Changed the PSU to the correct one for bequiet, its 850W.
6
Sorry for the double post, i wonder those 4 additional PCIE 6+2 connectors are those the 4 black ones next to the two red ones? Since they are only 6 pins and not 8 pins. I basically considered them as Molex only. This is a bit confusing.
DSzymborski
Polypheme
If this is the PSU you have, the built in ones should have two 6+2 pin connectors and the red ports on the PSU should be two connectors, each with two 6+2 pin connectors. It's right in your link! Specs on websites can be wrong, of course, but it would be odd to have only two 6+2 pin connectors on a PSU that's legitimately 1000W. Are you positive this is the model? There's only a single 1000W Gold-rated Chieftec.
Better safe than sorry, in the end of course. I know I always swap out warranty-expired PSUs, no matter how good or even if I have a single tiny suspicion.
It's a supreme irony if possibly the only time I argue for keeping a Chieftec results in it not being kept! lol
DSzymborski
Polypheme
Yes this is the PSU. The connectors are exactly as seen in this picture:
https://www.chieftec.eu/images/stories/virtuemart/product/02189.jpg
am i supposed to use the black connectors instead of the red for the 6+2 connections? That would be weird.
Cant do much if the Chieftec does not meet the requirements, if so i would have kept it too since it has been running well even 4 years after buying it.
No, according to the specs, the non-modular cables should have two PCIE 6+2 connectors and there should be four PCIE 6+2 connectors, likely split over two modular cables, to plug into the red ones.
Was this originally bought new? It sounds a lot like you're simply missing some cables.
(As for running well, that's always a guess unless you have some serious specialist equipment to test. It's a solid platform, so it probably has, but it's useful to remember that you never actually know; we mostly guess based on the quality of the PSU, since components being alive/dead isn't remotely a sufficient diagnostic measure).
Sep 4, 2020
6
It was bought new yes. The interface for the connectors at the back simply does not have the other PCIe connections necessary if they are marked in red. There are only 2 Red, 4 Black. The guy from Chieftec said in a mail its because there were two versions produced, one with the interface i have and one with more connections at the back.
