ATA bus speed for Dell OptiPlex GX1 series
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I recently purchased a couple of nice Dell OptiPlex GX1 series desktops on
eBay to clean up and give to family for email and web surfing. I want to do
a few upgrades to increase their performance prior to handing them out. One
of the things I would like to do is upgrade the hard drives so that they
will perform quicker.
Both systems habe OptiPlex GX1 series badges. One is a P3-500 and the other
is a P2-400.
The hard drive in the P2-400 is a Samsung 6.4GB drive that some reseach
shows is an ATA-33 drive.
The hard drive in the P3-500 is a Western Digital 75AA the my research shows
is an ATA-66 drive.
Both PCs had the "older" 30 conductor ATA-33 type of IDE cable instead of
the higher-density ATA-66 type of IDE cable.
Question: Do these PCs have IDE adapters on-board that can support an
ATA-66 or ATA-100 hard drive? I have a couple of 10GB ATA-100 drives coming
in to bump up the capacity and performance of these PCs and I would like to
know if I will be able to get the full use of their performance.
Anyone have any technical knowledge of these PCs that can answer this for
me?
Thanks in advance!
Keith
The OptiPlex GX1 series of computers use either an Intel 440BX (older) or an
Intel 815 (newer) chipset, depending on the vintage. Either one will accept an
ATA-100 drive, but I'm dead certain that the 440BX chipset boards will not run
the drives at ATA-100 speeds, even with the newer 80-pin ATA cable. I'm not as
sure about the 815 chipset, but I doubt that it, too, will run at ATA-100.
Probably ATA-66 max.
Both the 400 and the 500MHz machines very likely use the 440BX chipset. You can
go to the Dell web site and put in their service tags to get some further info,
altho not in the clearest format. Better still, if these computers are running
Windows, the Device Manager in the System icon of Control Panel will tell you
which chipset according to the device drivers used.
Your best shot at getting full performance out of the drives is to use a 3rd
party ATA-100 disk controller, such as Promise (market leader) or SIIG. Even
then, the relatively slow speed of the processor may slow down disk accesses.
.... Ben Myers
>is a P2-400.
>is an ATA-66 drive.
>me?
>Thanks in advance!
>Keith
No.
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:412569ab.28565172@news.charter.net...
an
accept an
run
not as
You can
info,
running
you
3rd
Even
accesses.
> ... Ben Myers
on
do
One
other
> >is a P2-400.
shows
> >is an ATA-66 drive.
coming
to
> >me?
> >Thanks in advance!
> >Keith
No? Then what? ... Ben
On Fri, 20 Aug 2004 00:03:18 -0400, "Mercury" <Mercury@matchmail.net> wrote:
>No.
>an
>accept an
>run
>not as
>You can
>info,
>running
>you
>3rd
>Even
>accesses.
>> ... Ben Myers
>on
>do
>One
>other
>> >is a P2-400.
>shows
>> >is an ATA-66 drive.
>coming
>to
>> >me?
>> >Thanks in advance!
>> >Keith
Since these use ATA-33 mobos, it is a "No" 😉 ....
news:41263e11.2061516@news.charter.net...
wrote:
> >No.
or
> >an
> >accept an
not
> >run
I'm
> >not as
ATA-100.
> >You can
further
> >info,
> >running
tell
> >you
a
> >3rd
> >Even
> >accesses.
> >> ... Ben Myers
desktops
> >on
to
> >do
out.
> >One
they
> >other
> >> >is a P2-400.
reseach
> >shows
> >> >is an ATA-66 drive.
of
> >coming
like
> >to
for
> >> >me?
> >> >Thanks in advance!
> >> >Keith
No, what? They won't accept an ATA-100 drive? Horsefeathers! The only
possibility as to why an ATA-100 drive won't be accepted is that the drive
capacity exceeds the limit supported by the motherboard BIOS.
An ATA-100 drive in an ATA-33 max system will simply run with ATA-33 command set
and speeds.
Try being more verbose. People cannot read your mind... Ben Myers
>wrote:
>> >No.
>or
>> >an
>> >accept an
>not
>> >run
>I'm
>> >not as
>ATA-100.
>> >You can
>further
>> >info,
>> >running
>tell
>> >you
>a
>> >3rd
>> >Even
>> >accesses.
>> >> ... Ben Myers
>desktops
>> >on
>to
>> >do
>out.
>> >One
>they
>> >other
>> >> >is a P2-400.
>reseach
>> >shows
>> >> >is an ATA-66 drive.
>of
>> >coming
>like
>> >to
>for
>> >> >me?
>> >> >Thanks in advance!
>> >> >Keith
Ben,
Thanks for your good responses. I appreciate that. (I agree - the other
responder could probably spare a few more words. Those responses had little
value. We can't read minds!)
I can't really get a good look at the writing on the Intel chips on the
mobos, but you are probably right about the BX chipset. I didn't know what
their max was (ATA-33 or -66). I was hoping they would at least be ATA-66
so I could squeeze a little more performance out of these systems.
Oh well, for what I paid for them (next to nothing) and for their intended
purpose (email, web surfing, light office apps) they should do fine.
Thanks again, Keith
If your systems are anything like Optiplex GX1s I've serviced, they have the
440BX chipset, both tower and small desktop setups... Ben Myers
On Sat, 21 Aug 2004 01:42:12 GMT, "KWA" <email@email.com> wrote:
>Ben,
>Thanks again, Keith
Ben
The question of the OP to quote exactly was
"Do these PCs have IDE adapters on-board that can support an
ATA-66 or ATA-100 hard drive? .....I would like to
know if I will be able to get the full use of their performance."
The complete answer remains *NO*... these mobos support ATA-33 therefore
using an ATA-66 or -100 will not give the OP full use of performance. In
other words the answer to his question remains in its entirety No.
If you want to be a showoff and attempt to showup other posters with your
'supposed' superior knowledge that is fine with me, but the answer given was
correct and answered the question completely. Not all of us have the time to
post encyclopedic answers to simple questions, but all courteous additions
are always appreciated :) .
news:4126ae0d.387725@news.charter.net...
the
> >Ben,
little
what
ATA-66
intended
> >Thanks again, Keith
The 815 supports ATA-66.
http://www.intel.com/design/chipsets/815/
an
accept an
run
not as
You can
info,
running
you
3rd
Even
accesses.
> ... Ben Myers
on
do
One
other
> >is a P2-400.
shows
> >is an ATA-66 drive.
coming
to
> >me?
> >Thanks in advance!
> >Keith
Here's a table.
http://www.eprom.com/home/faq/Intel(R)%20Chipset%20Comparison%20Chart%20-%20Value%20Desktop%20Chipsets.htm
"mdp" <markdpend@spambegone.aol.com> wrote in message
news:AbAVc.29194$9Y6.20815@newsread1.news.pas.earthlink.net...
or
> an
> accept an
not
> run
> not as
ATA-100.
> You can
further
> info,
> running
tell
> you
> 3rd
> Even
> accesses.
> > ... Ben Myers
> on
to
> do
> One
they
> other
> > >is a P2-400.
> shows
> > >is an ATA-66 drive.
of
> coming
like
> to
for
> > >me?
> > >Thanks in advance!
> > >Keith
I read the OP differently, and supplied a detailed response. But in your spirit
of brevity...
The Optiplex GX1 IDE adapters support ATA-66 or ATA-100 hard drives, but do not
allow the drives to operate at their full rated speeds. BIOS limitations may
prevent proper installation of drivers greater than 132GB.
In short, a response of "No" is incomplete... Ben Myers
On Sat, 21 Aug 2004 00:30:34 -0400, "Mercury" <Mercury@matchmail.net> wrote:
>Ben
>the
>> >Ben,
>little
>what
>ATA-66
>intended
>> >Thanks again, Keith
The OP stated "....I would like to
The complete answer remains "no" -- he will not get full performance, which
what I interpreted was the essential answer the OP wanted he know -- but we
can remain in a friendly difference on this one,
Cheers,
news:4126d4dc.10324048@news.charter.net...
spirit
> of brevity...
do not
may
wrote:
> >Ben
was
to
additions
have
> >the
> >> >Ben,
other
> >little
the
> >what
> >ATA-66
> >intended
> >> >Thanks again, Keith
Wonderful, but the GX1 uses the pre-815 BX chipset, so it's ATA 33
only I believe....
"mdp" <markdpend@spambegone.aol.com> wrote in message news:<mcAVc.29195$9Y6.17419@newsread1.news.pas.earthlink.net>...
> Here's a table.
> or
> an
> accept an
> not
> run
> not as
> ATA-100.
> You can
> further
> info,
> running
> tell
> you
> 3rd
> Even
> accesses.
> > > ... Ben Myers
> on
> to
> do
> One
> they
> other
> > > >is a P2-400.
> shows
> > > >is an ATA-66 drive.
> of
> coming
> like
> to
> for
> > > >me?
> > > >Thanks in advance!
> > > >Keith
