Athlon 64 x2 3600+ Overclock Help
zzuum
15
I am trying to overclock my old processor because its stuck at 1.9ghz. When I go into BIOS and set the number (not sure what it is called) from 200 to 225, it says
"IDE Channel 0 no 80 connector cable installed
Warning! Now system is in Safe Mode
Please resetting CPU frequency in CMOS setup"
The highest i can get it is to 202. Any ideas on whats going on?
After looking through BIOS, I only found a couple of options that included PCI. These where:
:Under Advanced Chipset Features
-PCIE SPREAD SPECTRUN [DISABLED]
-PCIE CLOCK [100Mhz]
:Under power management:
-Resume By PCI-E PME [Enabled]
-Resume By PCI PME [Enabled]
:Under PnP/PCI Configurations
-Init Display First [PCIEx]
-PCI/VGA Pallette Snoop [Disabled]
** PCI Express relative items **
-Maximum Payload Size [4096]
the : are menus and the - are options with the [] being the selected option.
Do any of these things have to do with that?
Lock the PCI-E clock to 100MHz, maybe you'd need to up the South Bridge voltage (ICH) by a bit.
I also just noticed, you got an AMD setup, I don't know much about AMD boards. I do know that in an Intel system the Southbridge voltage could sometimes be modified.
Sorry couldn't be a better help.
Any clue as to what you/we are dealing with? I know you have a 3600+, but what is the motherboard? Cooling? PSU? You shouldn't have to lock any buses to get above 202. My guess is you simply have a poor motherboard to OC with.
I have a GeForce 6100 motherboard with what I think is stock cooling, but not sure buecause it's alpine 7. either way its a fan. PSU is an Antec with 500w.
i have a crap winfast motherboard and an amd athlon x2 3600+ and i have mine running at 3.00 ghz now. for some reason i had to up the pcie mhz to be able to clock it so maybe look into adding 100mhz to that? depending on your vid card though. i have2 gts 250s so be careful. hope i could of been some help
