Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.hardware.overclocking,comp.sys.ibm.pc.hardware.chips (
More info?)
"keith" <krw@att.bizzzz> wrote in message
news
😛an.2004.10.13.03.01.18.706428@att.bizzzz...
> On Tue, 12 Oct 2004 21:34:06 +1300, Michael Brown wrote:
> > What actually happens in the *real* world? Assuming voltage remains
> > constant, how non-linear (with respect to frequency) is a transistor in
> > the range that it's typically being pushed in a modern CPU? And what is
> > the main contributor to that non-lineararity?
> The "real world" five years ago could be modeled quite like you propose.
> The power more-or-less proportional to the *active* CMOS power
> equations, much like; P ~ kCFV**2. Forgetting the "static" (or leakage)
> power, was easy since it wasn't a big issue (perhaps 10%). The world
> changed at 130nm and is getting worse exponentially as the structures
> shrink. (If you don't believe me look at the ratio of standby/active
> power of a PII vs. PIV at the same voltage.)
> Speed is still proportional to the voltage, but the power is proportional
> to (at least) the square of the voltage. What's changed is that the static
> (leakage) power is now a very significant part of the power budget. Since
> leakage isn't a resistive effect (current goes up at a higher rate than
> voltage) the power dissipated is even a higher-order function. Leakage
> sux! ;-)
> There are two major contributors to this power, sub-threshold leakage
> (essentially current through the ever-shortening channel when the device
> is "off"), and gate tunneling (current tunneling across the
> few-atom thick gate oxide). Both of these currents are a huge function of
> voltage. Both can be mitigated by a smart choice of devices and operating
> condiditons.
> A processor designed for a server may use lower threshold
> devices (that leak like hell) and very thin gate oxide (likewise). ...and
> pay for it in power dissipation. A laptop may make the oppposite choice.
> Indeed within a single system one can control the voltage (the only
> independent variable■) depending on the processing needs.
> ■ suspending clocks doesn't change the power for the work done,
> since 'f' is a linear function WRT power/performance.
> My issue here is that voltage is *not* a constant. Even the Pentiums had
> different voltage ratings across the product line. THe PII made it a
> function of the processsor module (but was still static). TMTA (I
> believe) introduced the concept of varying the voltage dependent on the
> processing needs. This is now a requirement.
> A single graph that shows power vs. frequency for a processor
> family doesn't show anything close to the whole picture.
> Keith
You are confused with a bunch of different concepts.
Your first confusions is about "voltage" and "product line".
Voltage is something engineers are using at will, to make
the product work for it's targeted frequency but staying
within reasonable reliability of devices and total power
envelope. The voltage is a variable that you can control
during your experiments with processor clocking and plotting
charts of processor power versus core clock. If you
want to compare two processors, one at 130nm, and another
at 90nm, to see how their power grows with frequency,
you run them at their corresponding _constant_ voltages
(and temperatures), and you get the picture I charted before.
Even if you are correct that "Pentiums had different voltage ratings
across the product line", you still can run each processor
at the same voltage while lowering core frequency down to
get data points. Or increasing frequency, as all overclockers do,
and they do change voltage at will.
If you are trying to compare same (similar? if can find one!)
processors on 0.35um, 0.25um, 0.18um, etc. process along the
frequency axis, then this is a different story, the story called
"CMOS scalability". Then yes, the classic CMOS scalability
is severely broken starting from 0.25um, so the voltages
between process generations are not going _down_ as they are
expected from proportional geometry shrinks (because you can't
shrink transistors proportionally any more because of various
atomic-level limitations). I guess one can call it "non-linear"
shrinks :-(
The original question was, as I read it, "what is non-linear"
with "transistors" as designs are pushed to higher frequencies
(as the original chart clearly implies). The correct answer is that
there is nothing really "non-linear" with CMOS transistor _GATES_.
The whole known methodology of designing processors is still
based on "flip-stay-flop" concept, therefore even today's
processors still follow the basic power formula. A quick
summary of CMOS power consumption basics can be found, e.g. here:
http://www.cse.psu.edu/~vijay/iscatutorial/tutorial-sources.pdf
Some (not very nice) discussion about common misconceptions
about leakage, dynamic power, and heat sinks can be found at RWT:
http://www.realworldtech.com/forums/index.cfm?action=detail&PostNum=1224&Thr
ead=1&entryID=14502&roomID=11
You can find there an example of how 0.13um Pentium-4 power scales
with frequency, all based on published specification data for Icc.
From these documents it is clear that I am the last person
who should be accused of "forgetting leakage".
What happens in "real world"? In high-performance processor world,
very simple - you push your design to the limits dictated by
throat-cutting competition, by tweaking geometry, process
corners, voltage, leakage, making thermal slabs and heat-pipe
based heat sinks, all for one reason - to maintain a foothold
in market share. When you hit a wall, everything is very
strongly non-linear - a brick wall
- aap
