ATI Graphics Drivers Problem!
Nisso
Hello Everyone! Ever Since I Fresh Installed Windows 8 on my aging desktop i have been unable to run ANY games due to my graphics drivers being outdated. however my graphics drivers are non existant as i find it imposible to install them!
When I Run The AMD Driver Installer It Says Right at the end that the install was completed with warnings. So when games still wont run i tryed again and all the packages were installed exept the one labeled AMD Graphics Drivers. I Have NO idea what to do!!! here is my GPU Info and system info after it
Name ATI Radeon HD 2400 PRO (Microsoft Corporation - WDDM v1.1)
PNP Device ID PCI\VEN_1002&DEV_94C3&SUBSYS_E400174B&REV_00\4&1D657AEE&0&0010
Adapter Type ATI ATOMBIOS, Advanced Micro Devices, Inc. compatible
Adapter Description ATI Radeon HD 2400 PRO (Microsoft Corporation - WDDM v1.1)
Adapter RAM 256.00 MB (268,435,456 bytes)
Installed Drivers aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
Driver Version 8.97.10.6
INF File oem1.inf (ati2mtag_RV610 section)
Colour Planes Not Available
Colour Table Entries 4294967296
Resolution 1440 x 900 x 59 hertz
Bits/Pixel 32
OS Name Microsoft Windows 8.1 Enterprise Evaluation
Version 6.3.9600 Build 9600
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name SAM-PC
System Manufacturer Acer
System Model M5610/M3610
System Type X86-based PC
System SKU
Processor Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz, 2200 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Phoenix Technologies, LTD R01-A4, 24/09/2007
If Any More INFO is needed Just say!!
Thnaks in advance
**NOTE**
Prior To Windows 7 Install The Games Were Playable!
**NOTE** During The Posting Of This Thread My PC Crashed and the audio made a Glitching sound. the whole display froze and then it shut off. the system booted normally tho
Hi
you need to find the correct graphics driver for Win 8
probably none exists for obsolete graphics cards so try Windows 7 (or Vista driver)
before installing it try to uninstall all traces of failed driver & reboot
before re installing
right click on installer from Windows Explorer and look for option to check compatibilty of program
run this test and then run setup and it may work
I had success with an obsolete Radeon x 1550 on Win 10 trial
the set up by itself failed before trying compatibility tester
this is probably driver for W 7 x86 (32 bit version) for your graphics card
http://support.amd.com/en-us/download/desktop/legacy?product=legacy2&os=Windows%207%20-%2032
If that fails try driver from manufacturer of graphics card instead of AMD
(sometimes they are tweaked from AMD version)
regards
Mike Barnes
