ATI Overdrive fan control doesn't work with Sapphire Radeon HD 4670?
Maximos
7
I recently tried to manually adjust the fan speed in Catalyst Control Center under the ATI overdrive section, but when I adjust the value I don't see a change in temperature or fan speed. Can someone help me out with this? Is it a problem with the driver or the hardware?
Thanks in advance.
Maximos
7
Managed to figure it out for myself, thanks a lot for your help. Turns out that since I ran the Auto-Tune for overclocking in Catalyst I was finally able to adjust it. Turns out it's very quiet too ;)
Thanks again.
G
Guest
Guest
I was having the same problem. Always low rpm and overheat, then driver shutdown. Tried many versions of software (new and old), nothing helps.
But when i turned option "CPU FAN smart control" to "AUTO" at bios, ive got my video card fan's rpm again adjustable, as auto and also manual.
P.S. Maybe its cause ive got intel proc. and amd graphics =)
