Ati power supply requrments
JapanFreak
8
will Radeon HD 6570 work with a 300w power supply?
if not can you reccoment me a good ati video card with hdmi that works with 300w?
i cant find better for my pc
can you recommend a video card with hdmi that works with 300w ?
What make/model of 300w PSU are you using? With that info, we can give you a better idea regarding your question. Also a list of the rest of your system specs would be useful as well.
+1 bigshootr8
JapanFreak you'll be fine. At 100% a Radeon 6570 only draws 60 watts. Add in the draw from your CPU, 65 watts? perhaps 105 at the most. Fan draw, DVD burner, motherboard, ect... that's all negligible. I doubt your max draw is over 165 watts.
Your only concern would be if you dropped in, say a 7770 or 7850. Mid range GPU's require an additional power from a 6 pin connector. Something your PSU would not have.
LOL unless your no name brand power supply can only put out 150W now.
